Need to flash my PCM ....
Old Mar 2, 2008 | 07:06 AM
vette96's Avatar
hi,
yesterday i was tuning my car using LT1 edit, every thing was ok for the first 2 times. until an error in communication accured then it erased part of the PCM memory, leaving me with a car cant start.
i sent email to the tech support they told me the PCM need to be replaced.
i have a used one and i need to flash it and put my car vin number in there... i was wondering what software allows me to do that??
some shops use it when they get a PCM to program... and dealers also.
i would like to get these tools so i can do it my self.
Any thoghts .......
Old Mar 2, 2008 | 09:20 AM
mrmint69's Avatar
I just loaded my tune yesterday. This web site had a program allowing me to use windows instead of dos to load it so you might give them a try. I just checked and it has the ability to change a vin on the pcm so use it at your own risk since i never used it for that. Goodluck!
http://www.tunercat.com/software/win...lash_setup.zip
This is a free 30 day trial but if all you need to do is use it once your fine. I am unsure if it works for your car so please check that also.
Old Mar 2, 2008 | 10:06 AM
VinceTrifecta's Avatar
Yes, Tunercat allows you to change the VIN (and I have used it for that). The only other tool that I know of that allows for this is SPS from GM (either via the Tech1/2 or a J2534-2 compliant programming cable).
If you need assistance repairing the corrupted PCM, feel free to PM me.
Old Mar 2, 2008 | 10:56 AM
sbs's Avatar
sbs
He appears to have a 96, in which case tunercat isn't going to help him.
Old Mar 2, 2008 | 11:00 AM
Good catch - in that case, GM's SPS w/ J2534 cable or Tech2 is the only solution I am aware of.
Old Mar 2, 2008 | 04:42 PM
mrmint69's Avatar
I was afraid being a vette and a 96 it would be questionable.
Old Mar 2, 2008 | 11:57 PM
vette96's Avatar
thanks for help guys,
i was thinking is some thing more independent,
when i send my PCM to TPIS the do it without hocking up my PCM to any car,
so there is must be a deivce that can be hocked up directly to the PCM to do the job.
i will be digging and keep every one informed if i find any thing as well. hopfully some one will benifit from this thread.
Old Mar 3, 2008 | 07:06 AM
That is because they have a bench system setup, since they do this kind of thing as part of their business. It may just be something home-made.
Old Mar 3, 2008 | 11:14 AM
The GT Tuner handheld could be modified to do this (without sending the PCM anywhere). All you need is a stock flash and the VIN re-written to a different PCM? Feel free to send me a PM if you're interested.
Old Mar 3, 2008 | 08:36 PM
sbs's Avatar
sbs
Bypassing the wire between the ALDL port and the PCM has absolutely nothing to do with whether the software can change the VIN...
Old Mar 3, 2008 | 09:33 PM
Red on Red WS6's Avatar
I know my OBD II Tuner Cat will do 96 and newer. Now that Jet own it does it not allow it?
Old Mar 3, 2008 | 09:50 PM
sbs's Avatar
sbs
I know nothing about the jet tuner (nee tunercat).
The discussion I responded to was about the currently available Tunercat product.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
