how to upload my pcmforless tune to pcm
Old Jan 10, 2008 | 06:10 PM
ajlew9428's Avatar
I got the tune from pcmforless, but dont understand how to upload it to the pcm. Ive tried, but nothing happens. Can someone give me step by step instructions or something to help me
Old Jan 11, 2008 | 08:38 AM
01Z's Avatar
01Z
Is this what you are lacking?
http://www.pcmforless.com/index.php?...d=44&Itemid=40
see the bottom of the page - LOAD YOURSELF.
Old Jan 12, 2008 | 09:29 AM
chasmosis1's Avatar
They send you the image on floppy. You must boot your computer from the floppy (dos) and flash it that way. Or if you have Tunercat you can just flash the image on with it.
Chas
Old Jan 12, 2008 | 02:13 PM
Boosted_Z28's Avatar
Which PCM tuning program are you using???
Old Jan 13, 2008 | 09:25 AM
chasmosis1's Avatar
Here is a quote from the email that Bryan sent me when I had him do my tune. If you are running XP than you may need to download winflash. Hope this helps.
Chas
Attached is your file. What you do is save the program from the email and run it. It is a self extracting zip file and will save all of the necessary files to the temp directory. Then go to the temp directory with a formatted floppy disk in the a: drive and run install. This will make a boot disk with all of the necessary files. Then put the boot disk in your a: drive and restart your computer. This will start the computer in DOS mode as you cannot run this software in windows. There are instructions through the process. I recommend running flshread first after booting off the floppy. This way you can save your stock program and test your new cable at the same time. Reading a PCM can never do harm to it. Under no circumstances should you ever run flshprog.exe or flshread.exe in WINDOWS. They can only be run off the boot disk or after the computer has been restarted in MSDOS mode only.
If you are running windows ME or XP, or just have problems with the boot disk and/or dos, you can download the windows version of the loading software at
http://www.tunercat.com/software/win...lash_setup.zip
Using that software you can load the .bin file that is attached that is named as your name.bin where your name is your first initial and last name.
Thanks for your order,
Bryan
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
DSMKilla
May 26, 2015 10:10 PM
thenewkid
Apr 12, 2015 07:42 PM
turbo_Z
Aug 19, 2002 10:50 PM
