considering buying Autotap
Old Feb 23, 2008 | 06:16 PM
camzaro28's Avatar
http://www.autotap.com/product_famil...&TrailType=Top
This is new stuff to me, so just want to make sure I would be purchasing the correct stuff.
The first is ATU, which is the USB port. Does that mean the cord going into my laptop?
2nd do I need the enhanced GM parameters for the xtra $99?
Is that all I need, or am I missing anything?
Old Feb 24, 2008 | 03:02 PM
Red on Red WS6's Avatar
I have been using Autotap for a couple years now, I also have the USB version. I don't have to many complaints. For sure get the enhanced parameters.
Old Feb 29, 2008 | 05:31 PM
mr_camaro96z28's Avatar
Red on Red WS6 you say you dont have many complaints about AutoTap and I am also considering buying it. If you dont mind what are your complaints?
Old Mar 1, 2008 | 12:54 AM
The first year I had it I was getting a bunch of error codes and had to keep emailing them about it. Since their last couple updates I don't really have many issues with errors. The only downside of it, is every different car I do data logging on I have to make a new configuration file after it scans perimeters. Not really that big of a deal I just do not like the default config.
Over all I think it is a great buy and is a wonderful tool.
Old Mar 1, 2008 | 08:47 AM
JWS6's Avatar
My only complaint is that it shows your fuel trims in %'s and NOONE on the 'net uses percentages.
Old Mar 1, 2008 | 10:01 PM
Showing fuel trim in % is really weird ive never heard of that befoer. have you ever asked them is there is a way to convert it?
Old Mar 2, 2008 | 01:39 AM
I thought it was kind of weired myself since everyone is always referring to 128. But it really is not that big of a deal for me now. It has been asked if they can make an option to view either or & I can't remember the reason they can't or wont do it though as it was a couple years ago.
This the statement is directly off my Autotap for LTFT%
Scan Tool Range -23% to 16%. Long Term Fuel Trim is derived from the Short Term Fuel Trim value and represents a long-term correction of fuel delivery. A value of 0% indicates that fuel delivery requires no compensation to maintain the PCM commanded air/fuel ratio. A negative value significantly below 0% indicates that the fuel system is rich and fuel delivery is being reduced (decreased injector pulse width). A positive value significantly greater than 0% indicates that a lean condition exists and the PCM is compensating by adding fuel (increased injector pulse width). Because Long Term Fuel Trim tends to follow Short Term Fuel Trim; a value in the negative range due to canister purge at idle should not be considered unusual. The PCM's maximum authority to control long term fuel trim allows a range between -23% and +16%. Fuel trim values at or near maximum authority may indicate an excessively rich or lean system.
Old Mar 4, 2008 | 05:59 PM
Steve in Seattle's Avatar
Just on a side note, I was playing with my tuner's Mac Mentor professional scanner this weekend (a $3000+ tool), and it gives fuel trim values in percentages.
The idea that "no one" uses % is bogus. Some very powerful, very expensive tools actually consider that a FEATURE. (and yes, it makes more sense than reading a count IMO).
Just a thought.
warmeck
Jul 17, 2015 01:36 PM
NewsBot
Jan 8, 2015 11:29 PM
Ricardo
Nov 29, 2014 10:58 AM
Pentatonic
Aug 27, 2002 11:38 PM
