Low Coolant Light
Old Feb 9, 2008 | 02:10 PM
bill2740's Avatar
Low Coolant Light
I have a 1997 30th Aniv.Z-28 with 53,000 miles. The DEX-COOL has been changed twice (and flushed). Yesterday, the coolant warning light came on. I checked the recovery tank and the radiator. I added less than 1 pint to the radiator (full).
The coolant warning light stays on. Engine temp normal.
Why doesn't the warning light go out???
Old Feb 9, 2008 | 02:56 PM
The low coolant switch if a common failure on the 4th Gens. Pull the switch and try cleaning it. If it still doesn't work, either replace it, or simply unplug it to turn out the dash light.
Courtesy of Shoebox:
http://shbox.com/1/low_coolant.jpg
You radiator should never need any coolant added directly to it, though. The reservoir should accpet the overflow as the coolant heats up and expands, and return the coolant to the radiator when the coolant cools down and contracts, keeping the radiator full. If you had low coolant, you may have a problem.
Old Feb 9, 2008 | 06:30 PM
bill2740's Avatar
Thank you for the good info. I found the module and the 2 way connector under it. How can I disconnect the 2 way plug without destroying it? Just pull down on it?
I bought the car, new, in Miami and its been my baby ever since.
Old Feb 9, 2008 | 06:37 PM
moparman's Avatar
IIRC, there is a wire bail that holds the sensor. Loosen the wire and the sensor should pull out.
Old Feb 9, 2008 | 09:15 PM
Most GM harness connectors have a spring "finger" that has to be lifted off the matching lug on the sensor to release the harness connector. If it wasn't so cold in the garage, I'd go look at mine and let you know.
Looking at Shoebox's picture, you can see the "finger" right above the "m" in the .com watermark.
Old Feb 10, 2008 | 10:27 AM
bill2740's Avatar
Thank you guys.
It was a dirty connection. It works now.
Thanks again,
Old Feb 11, 2008 | 12:16 AM
sbs's Avatar
sbs
Only changed coolant twice in 12+ years?
Old Feb 11, 2008 | 11:50 AM
bill2740's Avatar
Smile
"The coolant is designed to remain in your vehicle for 5 years or 150,000 miles, whichever comes first". I called GM on this.
Old Feb 12, 2008 | 12:04 AM
sbs's Avatar
sbs
Which is perfectly fine if you are the one providing a 3 yr/36k warranty on the engine.
Not so good for the person who buys a new car to keep forever. Or the person who buys that car secondhand...
Old Feb 12, 2008 | 06:33 AM
bill2740's Avatar
Who is the EXPERT on this, you or GM, I think GM. Do you have any facts to back up your opinion.
NOTE: Opinions are like a$$holes, everyone has one.
Old Feb 12, 2008 | 06:17 PM
n2ceptor's Avatar
Apparently, you didnt notice the vehicle only has 53,000 miles....
Old Feb 17, 2008 | 04:07 AM
canuck94z28's Avatar
Coolant change
I had the green coolant in my 94 originally(even though o.e wp failed under warranty) and when i changed over to the orange stuff i was glad the intervals were longer b/c the local Canadian Tire repair shop got my stupid opti wet and luckily it dried outSo anything you can do to reduce the chance of screwing up a opti(esp.on93/94)is good imo.Btw i probablywill put fresh coolant in when i put in my Msd opti this spring.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
