probably a stupid question....
Old Feb 26, 2008 | 09:55 AM
Colin91Z's Avatar
I had a scanner on my car the other day, and other than running rather rich, the only thing I noticed that didn't seem right was that my TPS read 5% at idle. Is that what it's suppose to be, or should it be 0%? The car has a holley 58mm tb on it btw....
Just trying to figure out if I need to slot my TPS or not
Old Feb 26, 2008 | 10:41 AM
Throttle position percent is figured by the PCM based on the closed throttle TPS voltage. What is the TPS voltage showing when the TPP shows 5%?
Some OBD-II hardware scanners appear to show a positive number for TPP at idle.... but the software scanners show the correct 0%.
Old Feb 26, 2008 | 10:48 AM
Colin91Z's Avatar
I'm not sure I didn't look at the voltage. I'll put the scanner back on it this afternoon and report back...
Sorry, I'm a noob when comes to figuring out the tune on these things
Old Feb 27, 2008 | 10:58 AM
VinceTrifecta's Avatar
I believe the PCM will also store its scale of the TPS % vs. TPS voltage. I found on my Impala SS that if I increased the TPS voltage by adjusting the TPS, it would go from 0% to 1%, but I'd still be below .95v. If I disconnect the battery, reconnect it, the PCM would "reset" its calibration of the TPS to 0%.
I also had to slot my TPS for my BBK 58mm throttle body.
Old Mar 5, 2008 | 12:55 PM
Colin91Z's Avatar
Ok, finally got a scanner back on it. TPS voltage at idle was .76v and now reads 0% (somehow my tps was not seated all the way on my tb)
But i figured out what my drivablity problem was too....my left o2 was sticking on a lean reading, so my injector pulse was waaay up on left bank. No wonder it was being sluggish and puffing black smoke occasionally
Old Mar 5, 2008 | 01:24 PM
Awesome!
93 RedBird
Nov 15, 2015 08:24 AM
NewsBot
Sep 14, 2015 09:20 AM
cmsmith
Aug 9, 2015 07:30 PM
FredM
Jun 5, 2015 05:45 AM
