Can only get 10PSI of boost
Old May 4, 2008 | 01:03 AM
sean-k94z's Avatar
I think I might not have my boost controller setup right but I have another concern. My waste gas has a 10 psi spring, but it sure sounds like it wants to build more boost. Can you tell by looking at this log file if my turbo has "run out of steam".
Im running a 355cid LT1, T70 .96exh, stock manifolds, 2.25" crossover, 3.5" turbo back exhaust, PowerEFI megasquirt ecu
Thanks,
Sean
Old May 4, 2008 | 01:58 AM
dookie454's Avatar
Looks like MAP is constant.. then a huge leak develops.. then continues on with MAP constant.
I never see increasing MAP values.. so I would say yes.. at no point do I see an increase in boost.. could mean two things:
1) Turbo isnt capable of generating more boost
2) a huge leak is responsible for the loss of boost
3) your left wondering if it's the turbo or leak resposible for lack of boost increase.
Old May 4, 2008 | 01:59 AM
dookie454's Avatar
Thanks,
Sean
BTW, my concern would be the knock - according to the logs.
Old May 4, 2008 | 02:13 AM
sean-k94z's Avatar
I'll check all my clamps etc. I figured the turbo wouldn't be maxed out until about 14psi or so........ I'm not too worried about the knock, its doing its job. It's only pulling 6 deg. That dip isn't a leak, i lifted off of the throttle(blue line).
Old May 13, 2008 | 12:20 PM
sean-k94z's Avatar
Hauls now!!!
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
