stroker tuning
Old Apr 30, 2008 | 11:27 AM
Bails098's Avatar
stroker tuning
383 stroker low compression for nitrous, edelbrock ported heads, intake and 58mm throttle body, 1.6.1 rockers msd ignition/coil i forget the cam numbers. I am looking for a stand alone system any suggestions
Old Apr 30, 2008 | 12:01 PM
tapout911's Avatar
Fast xfi or big stuff 3. Im shopping around myself. Those 2 seem to be the easiest to install.
Old Apr 30, 2008 | 08:07 PM
rskrause's Avatar
Moderator
Why do you think you need a stand-alone? What functions do you need? That will determine which, if any, is the best for you.
Rich
Old May 3, 2008 | 06:06 PM
Bails098's Avatar
right now i have a mail order tune, is this sufficient for what i need with a 150-200 shot?
Old May 3, 2008 | 09:41 PM
rskrause's Avatar
Moderator
If it's a wet system with the correct nitrous:fuel ratio and has some timing taken out, it should be fine.
Rich
mrwz28
Jul 8, 2015 09:11 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Drtryder
Apr 22, 2015 04:17 PM
