TTS Datamaster. How does it work?
Old Feb 21, 2008 | 10:36 PM
mrmint69's Avatar
I downloaded the 20 free TTS Datamaster program. I tried to run a datalog but could not get the data on my laptop afterwards to show up. What do you do so i can read it on my laptop? My Freescan works great but this ones has me stumped.
Old Feb 21, 2008 | 11:26 PM
You have to go to File>Record ALDL Data.
When the Serial Data Acquisition window opens click Setup and select the appropriate Com Port.
Then select File>Open... and input a file name.
Run engine, then press the Start button.
Press Stop when you are done.
Old Feb 21, 2008 | 11:29 PM
2xLS1's Avatar
They describe it pretty step by step in the help file. Just hit the F1 kwy with the program open. Then Recording ALDL Data.
Old Feb 22, 2008 | 02:35 PM
mrmint69's Avatar
I went throught the steps like you said and it was recording and it looked like everthing was working correctly. Afterwards i could not find the file to see the results, so where should they be?
Old Feb 22, 2008 | 04:26 PM
By default the log is stored in the TTS>Datamaster>Testdata program directory or you can choose to store it anywhere (just like any other file you would save on your computer).
Old Feb 22, 2008 | 04:53 PM
11secgen's Avatar
look for two files in there, i got confused and was reading the test file.i saw one in there and thought it must be working,but i wasnt even linking up w/ the pcm.it turned out to be a cable issue(serial to usb adaptor) that was the problem.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
