flashing lights
Old Mar 7, 2008 | 06:18 PM
95z28_m6's Avatar
flashing lights
I have a problem. When the car is running on the dash the low trac and brake lights flash. At the same time you can hear a click from under the hood. I havent had time to look at it yet but i was wondering if this was a common problem or if anybody has had something like this before. Im thinking either a bad ground or possibly a relay gone bad or something to that effect. I will get a chance to troubleshoot it tomorrow. Any help or ideas would be great. 95 z28 mods in sig
Old Mar 7, 2008 | 06:49 PM
Check the ground on the RH shock tower.
Old Mar 7, 2008 | 07:01 PM
95z28_m6's Avatar
Well that would make sense because i just put on front drag shocks. I dont remember a ground though. Ill deffinately check that out. Thanks.
Old Mar 13, 2008 | 08:45 AM
Colin91Z's Avatar
So did that solve the problem? Just curious, my friends 94 is doing the exact same thing and I'm hoping its something as simple a bad ground....
Old Mar 13, 2008 | 09:17 AM
Colin91Z's Avatar
nevermind....it's comfirmed
I found a loose ground on the right hand shock tower, just like shoebox said, tightened it up and no more flashing lights
Old Mar 13, 2008 | 02:43 PM
95z28_m6's Avatar
actually I havent had time to look at it yet. I think tonight after class I will stop by for a few mins and play with it. I think I might even put on my underdrive pullys too.
Heathen1
Jan 2, 2016 04:27 PM
dfarr67
Apr 10, 2015 07:44 PM
BigWil
Mar 29, 2015 12:24 PM
jasonduaine
Mar 7, 2015 09:44 AM
Jul 4, 2005 05:00 PM
