cant connect to read code
Old Apr 23, 2008 | 01:31 PM
luckyou03's Avatar
Well my car has fun power, starts up , idles fine for about 1 minute and shuts off fine but if I idle for more than the length of a red light, it throws a check engine light and dies. I die at almost every red light now with SUCKS. So I went to 2 different autozones today to get the code checked and both times there scanner said error something can't read code or connect. I have checked all the fuses, there device is getting power so that plug has power. Any suggestions?
Old Apr 23, 2008 | 01:37 PM
Most auto supply places will only scan OBD-II cars. Your 1995 has a connector that is the same as used with OBD-II, but the computer is OBD-I. Therefore, these places often tell you that your computer has a problem (when it is actually them not using the right scanner).
You will need an OBD-I scanner with the correct adapter cable or you can adapt a 12 pin cable like this.
Old Apr 23, 2008 | 01:57 PM
luckyou03's Avatar
they did ask what year it was and said that it needed to be 96+ but the connector looked the same. I have the cable myself and I'll setup my computer in the garage tonight to see what the sensors are doing. Thanks for that bit of information.
DirtyDaveW
Dec 1, 2016 05:37 PM
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
