Differences between 94 and 95 LT1 programs?
Old May 4, 2008 | 02:11 AM
whitehooptie's Avatar
I know there are some dfifferences between the two. What are the major ones? I am curious because of a knock sensor issue.
Old May 4, 2008 | 03:33 PM
jay_lt4's Avatar
manual trans or auto,
the auto trans on a 94 is tcc-on/off
the auto trans on a 95 is pwm (pulse width modulated)
the knock sensors are the same
Old May 4, 2008 | 11:48 PM
I was curious about the tranny. Knock sensor programming is different between the 2.
Long story short, on a 94 program, if the knock sensor is unplugged, it won't throw. 95's will. Just wondering is there was a programming differnce between the 2.
Old May 5, 2008 | 07:02 AM
You are saying if you disconnect the knock sensor, it will not cause a trouble code? That makes no sense. The OBD diagnostics are the same. Sounds more like something is wrong (or altered) with the PCM.
Old May 5, 2008 | 01:00 PM
Pretty much. Right now, the knock sensor wire is cut and am not throwing a code what so ever. The scan tool I have also says that the pcm is receiving a knock sensor signal. This is on a 94 program. I can put ANY program from a 95 in there and it throws a code 43 as expected.
I was truly curious because my knock sensor is super sensitive or something. I've got a big cam, heads, long tubes and all that but I can not keep the "knock" out of it. No it is not detonating at all. I was wondering for sure if maybe the 94 was a little more "touchy" than a 95.
Old May 5, 2008 | 03:54 PM
NVetro's Avatar
Didn't some LT1's have (2) knock sensors? one on the left side of the block and one on the right side?
Old May 5, 2008 | 07:28 PM
Yes, but not in an F-body.
InfernalVortex
Jan 17, 2015 09:35 AM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
