Obdii Dtc P1416
Old Mar 13, 2008 | 10:31 PM
HD63FLH's Avatar
Obdii Dtc P1416
I have a 97 T/A that has recurring P1416 trouble code coming up. Does anyone have any suggestions as to how I can proceed without going through replace with known good part? I'm not sure where I should start on this. Any help would be appreciated. Thanx.
Old Mar 14, 2008 | 07:39 AM
ZZZ96Z28's Avatar
you have mail
Old Mar 14, 2008 | 07:55 AM
2000GTP's Avatar
P1416 is the following code: Secondary Air Injection (AIR) system Bank 2
It could just be a faulty check valve. I would also check the line to make sure there is no damage. If you are unfamilar with the check valve, here is their location courtesy of Shoebox:http://shbox.com/1/diverters.jpg
Old Mar 14, 2008 | 10:57 AM
HD63FLH's Avatar
Thanks for the flow chart 96Z and the valve location 2000 GTP. I will see if I can locate the problem this weekend with the help you have provided.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
