Injector Programing????
Old Mar 3, 2003 | 01:09 PM
hosspwr94's Avatar
Question Injector Programing????
I am new to the tuning stuff and need some advice!
I have just installed 30# Injectors.....
With Tuner Cat, do I need to change all the tables or do I just need to change the constant? Does the computer set the tables after you set the constant?
Old Mar 3, 2003 | 01:35 PM
Momar's Avatar
I have not done any tuning like this myself but have been studying it for a while and reading about what people do. From what I understand you just have to change the injector constant. I think of it as functioning as part of an eqation. When you change it your tables may not actually change but since it is part of the equation the actual output you get from the tables will which will result in proper injector pusles. If this is incorrect someone correct me, but I am pretty sure that is how it works.
Ben
Old Mar 3, 2003 | 01:39 PM
madwolf's Avatar
The computer won't change the injector offsets if you're reffering to them. You definetely need to update the constant though. (Set it to 31.6 since this is their equivalent flow rate on LT1s... they were originally rated at 39.2 PSI and LT1 runs on 43.5)
You can also try this table for 30# SVO calculated offsets, but you'll have to convert those values from Milliseconds (lt1_edit) to Microseconds (tunercat). Many tuners choose to not update the offsets.
Old Mar 3, 2003 | 10:25 PM
Dan K's Avatar
I have yet to see a file where someone changed the offsets when using 30# SVO injectors.
Has anyone done it in their car?
Old Mar 3, 2003 | 10:43 PM
drop top steve's Avatar
I changed constants and it greatly improved starting, both cold and hot. My crank time is one second or less under any condition I've had so far.
Old Mar 3, 2003 | 11:15 PM
Dr.Mudge's Avatar
I used Christian's 24# table and things worked fine, but there was always a little debate on what the actuality was. I dont think anyone was ever really able to produce a true 30# table, maybe now that is an easier thing to find. I think someone found a table for 36# or 42# from a Lightning and it wasn't the same.
Old Mar 4, 2003 | 12:19 PM
hosspwr94's Avatar
Cool Injector Offsets
Thanks for all the help! This should help get me back on the Fast Track!
I am going to try changing the offsets along with the constant, Is there anything else that needs to be changed or updated?
Old Mar 4, 2003 | 12:27 PM
Dr.Mudge's Avatar
Thats pretty much it, I've seen files where people didn't change the offsets at all. Kind of like some people who actually dont change the cubes in the program when they stroke, they just play with injector constant, kind of funny but like using the MAF to tune things, some people just do it differently.
Old Mar 4, 2003 | 12:42 PM
Momar's Avatar
Yes, but like I said, it is all a big equation so there are several ways to get to the end result. Some more, and some less complicated.
Ben
RUENUF
Mar 13, 2016 03:37 PM
4586
Aug 22, 2015 01:09 AM
Slayer
Aug 17, 2015 03:55 PM
whitehooptie
Aug 10, 2015 07:02 AM
Anon
Jul 23, 2015 12:18 PM
