Anyone using an EMP-10 to reprogram thier Flash chips... Questions inside...
Old Mar 2, 2003 | 11:10 PM
roguedriver's Avatar
Anyone using an EMP-10 to reprogram their Flash chips when they lose the Flash? I just got an EMP-10 and was wondering if I need a special socket to program these Flash chips in the EMP-10. I've socketed my PCM so there easily removable. Whats the quick and dirty on how this setup works and what I need to do to reflash each chip? New to this end of it. After using the EMP-10 software to reflash, are the chips ready to reinstall in my PCM and then accept my program, or do I need to do other programming to the Flash chips before reinstalling them in the PCM. Any help would be appreciated. Thanks.
Ken R. 95Z
Old Mar 3, 2003 | 02:01 PM
kevin97z28's Avatar
roguedriver The EMP-10 may not support the device you are using. The EMP-10 is a lower cost programmer, the device support list is very limited. You may have to upgrade to EMP-30 or something of this nature in order for it to be able to read/write to the "chip" you are using. Also most programmers are setup for DIP configuration. So you will need an "adapter" to program and read the chip. I am not sure what package you are working with but most LT1 flash chips are PLCC. The LS1 PCM's utilize a TSOP package. so you would need either a:
1. PLCC----->DIP adapter
2. TSOP----->DIP adapter
Maybe this helps out.......Kevin
Old Mar 3, 2003 | 11:49 PM
Thanks...
Thanks Kevin. The EMP-10 will support the flash chip I need to flash. It's in the list of supported devices. What I don't have is that adapter and thats what I wanted to know about. I'll have to pick one up. Thanks.
Ken
Old Nov 24, 2009 | 10:59 AM
rkikendall's Avatar
Sorry to bother you, with a reply to an old post, but I'm looking for the software for the EMP-10 programmer. I have an EMP-10, but can't find the software I had. Any help will be greatly appreciated. Thanks so much.
Ryan
Old Nov 24, 2009 | 11:29 AM
dookie454's Avatar
this might be useless info, but I used a Willem programmer off ebay, $24.
Do you have the chip images? I have OBDI T and E images, 64K each.
Old Nov 24, 2009 | 03:18 PM
94ZRagtop's Avatar
I have the DOS EMP-10 software. Email me at andrew at akmcables dot com and I will hook you up. My EMP-10 is still fully functional and I still use it.
jasonduaine
Mar 7, 2015 09:44 AM
HCz28
Feb 15, 2015 03:01 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Rod Bender
Jan 3, 2015 03:15 PM
Jul 4, 2005 05:00 PM
