Torque management
Torque management
I have heard the LS1 owners in our club talk of turning this off in their cars and seeing some good gains from it.
Do the LT1 OBDI cars have this to turn off? If so what is that table called and what do I set it to to turn it off?
BTW I am using TunerCat so it may be called something different than in LT1_edit.
On the C5 LS1's, there is a torque management system, that is part of the traction control system. The electronic brake traction control module (EBTCM) tells the PCM what torque is required, and the PCM adjusts torque output and sends the "delivered torque output" PWM signal to the EBTCM. Not sure if the same system is used on the F-Bodys, or how similar this might be to the LT1 PCM controls.
