TunerCat EEB file
TunerCat EEB file
Does anyone have an EEB file for tunercat? If you know for sure you have one would you please send me a copy. perfer stock but will take whatever.
LewisW96@attbi.com
LewisW96@attbi.com
EEB is a ECM Definition File and "The C.A.T.S. Tuner program uses a unique ECM Definition File to define the ECM parameters for each unique type of ECM. " taken from C.A.T.S help.
There is no such thing as a stock one, are you sure this is what you need?
EEB is not for our cars, just so you know. If you modify your camaro/firebird file in the EEB definition file and try to download it to your PCMthe car will not run. I found this out the hard way thinking that the EEB file was the updated ee file from tunercat. It messes with the injector constants as well as cylinder volume constant. The speedometer won't work as well, but i realized what i did and corrected it. Just FYI
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
