Just got tunercat where do i start???
Old Mar 19, 2003 | 08:31 PM
johnpsz's Avatar
Ok everyone this is what I've done or plan to do(insert you help here!), I've just gotten tunercat got the definition files I need, and downloaded a crap load of .lt1 and .bin files(as well as software to convert .lt1-.bin).
I am going to look over all the different files and compare them with what I've read from my stock program, consolidate the information and make a tune for my car, mods below/not many, is this the best course of action or is there a better way to start, if so where, and how do I learn?
Thanks for the help,
Old Mar 20, 2003 | 01:02 AM
Dr.Mudge's Avatar
Tunercat can open either file, you just need to remember to save .LT1 files as .BIN, if you are going to program your PCM with it. This is because LT1 Edit and Tunercat store the T and M chip data backwards of each other.
Study the various tuner introduction guides out there.
http://hometown.aol.com/dvandrews/ems.htm
http://www.bfranker.badz28.com/fbody/links.htm#PCM
http://www.customefis.com/links.html
http://www.carprogrammer.com
http://www.geocities.com/ecmguy.geo/
http://www.andywhittaker.com/ecu/ecu_software.htm
http://diy-efi.org/diy_efi/projects/diy_wb/
http://para.noid.org/~lj/PCM%20Tutorial/PCMtutorial.htm
http://www.geocities.com/steve3034/links.html
http://www.wotelectronics.com/cables.html
Good sensory overview
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Mar 20, 2003 | 07:03 AM
johnpsz's Avatar
thanks,
This is great information and it looks like it will be a while to take it all in, but I have one question after reading some of that.
Where do you find the PE tables in tunercat? or is that just info retrieved from the scan tool. Oh what is the best(cheap or free) scan tool out there?
Old Mar 21, 2003 | 01:37 AM
carnutz's Avatar
Do a serch on 'freescan" you can download it for free, seems to work fairly well.
You other question I cant Answer
Old Mar 21, 2003 | 01:49 AM
Dr.Mudge's Avatar
PE consists of 2 tables
%change to Fuel/Air Ratio vs coolant temp @ WOT
%change to Fuel/Air Ratio vs RPM @ WOT
Freescan
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
smackkk
Jul 22, 2002 05:17 PM
