is this too much timing?
Old Apr 1, 2003 | 06:32 PM
Fbody1's Avatar
Question is this too much timing?
is this too much timing, 44 degrees @12% throttle@1700 rpm , sometimes 45 degrees with cruise on@75 mph , hot cam 1.6RR, 355ci,ported heads,intake ,11.4 comp ratio, 52mm,headers, borla,orp,msd ,stock MAF,cai,M6,LT4 km, getting some retard,was wanting some opinions
Old Apr 4, 2003 | 04:10 PM
rickb@lynk.com
Guest
Posts: n/a
My timing is similar and I have only seen knock when shifting around 3000 rpm. Usually this is from 1st to 2nd accelerating from a stop but I have seen it when downshifting from 4 to 3 at around 75 mph as rpm climbs to 3000. In neither case was I 'ON' the throttle. Usually 30-50% tps.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
