Should I bother
I'd fix the knock first. I'm not sure how... I think to find out if it is actually real knock, you can buy a really high octane gas... and if you still get the knock it should be false knock. If it is real knock, I think it could be caused by carbon buildup if you have a lot of mileage on the block. A band-aid to this could be to retard the timing a bit when you tune it... sure you'll lose some power, but less power than the PCM takes away with the knock retard.
Jun 26, 2015 03:00 PM
cmsmith
Apr 11, 2015 09:37 PM
