Will this cable work with LT1edit/free scan on my 95 Z?
Old Apr 5, 2003 | 06:56 PM
BackInBlackZ28's Avatar
Question Will this cable work with LT1edit/free scan on my 95 Z?
I found this really nice cable for $70, wondering if it will work with my laptop for freescan and lt1edit? I have a 1995 Z28 with OBD 1 and an OBD 2 connector.
http://www.scantool.net/universal_obdii_cable.htm
Old Apr 5, 2003 | 06:59 PM
Or do i need this board too?
http://www.scantool.net/elmscan_vpw.htm
Old Apr 6, 2003 | 12:55 AM
turbo_Z's Avatar
that is only the cable so it wont "read" anything. what you need is an actual interfacing cable with a chip that deciphers the PCM signals into info your scanner can read.
you get them here and they are only $65
Old Apr 6, 2003 | 03:23 AM
Dr.Mudge's Avatar
Yep, thats a cable with no brains. You can buy the regular OBD I kit and just put the pins in the connector, you dont need the OBD II connector, they are usually pricey.
Old Apr 6, 2003 | 10:42 AM
How about the cable and this
It for OBD 2 i just want to make sure it will still be able to read my OBD 1 computer, but plug into my ALDL port. I justwant a cable i can use on my 95, but also use to iagnose my moms 98 Grand Prix when needed. Thanks
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Sarahrope64
Nov 27, 2014 11:17 AM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
