Injector constant and offsets??
Old Apr 7, 2003 | 06:25 PM
96z's Avatar
96z
Again another question with a program I want to use....
The program uses 30lb SVO's at a 30.007 constant with the stock GM offsets....Im going to be using 36lb SVO's....So should I use a 36.007 constant and the stock offsets, or use the SVO 36's?
Anyone notice any beneift with using the correct offsets?
Old Apr 7, 2003 | 06:30 PM
madwolf's Avatar
SVO Injectors were rated at 39.2 PSI. Our cars run at 43.5.
The formula for figuring out the new flow rate is:
newflowrt = sqrt(newpress/oldpress)*oldflowrt
So the correct setting for the 30 SVO injectors would be 31.6 lb/hr and for the 36ers, 37.92 lb/hr.
As for the offsets, I would try the stock ones first, then the updated ones. Scan the car and watch the BLMs for both settings. Stay with whichever yields better results.
13qtr
Oct 28, 2016 08:11 PM
marlar98
Sep 19, 2015 07:53 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
