Gas Tank Question
Old Nov 17, 2004 | 11:37 AM
Buck89RS's Avatar
Gas Tank Question
What is the best way to empty my gas tank? I cant seem to get a hose in the filler to siphon it out so now what?
-Buck
Old Nov 17, 2004 | 12:16 PM
OutKast's Avatar
Re: Gas Tank Question
most newer tank /filler necks have made just about impossible to siphon it out. My best suggestion would be to disconnect the fuel line at the filter and turn on the pump. Might not get it all out but probably more than a siphon would do.
Old Nov 17, 2004 | 12:55 PM
HBHRacing's Avatar
do to check ***** it's hard to stick a hose in the filler necks. you can jump the prime connector with the feed line unpluged at the filter but it puts a lot of strain on the pump. Why do you need to empty the tank?
Old Nov 17, 2004 | 01:07 PM
Buck89RS's Avatar
Dead gas. Has been sitting since 96.
-Buck
Old Nov 17, 2004 | 01:34 PM
HBHRacing's Avatar
Drop the tank. Your gas is no longer a liquid. It's now a thick green sludge. Get a new pump, sending unit, filter and have the tank steam cleaned. The injector might be damadged as well.
Lonemechanic
Feb 19, 2015 10:29 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
guionM
9
Aug 29, 2002 01:48 PM
simple
Aug 11, 2002 11:56 AM
