car starting problems
Old Oct 1, 2004 | 07:21 PM
drdudelove's Avatar
i have a 95 3.4 liter and lately i have had a hard time getting the car started. i thought it might help if i changed the fuel filter and did that and for a while the problem seem to go away but it has gotten bad again. if i give it a lot of gas when starting it helps but this is not an old muscle car like my other so i should not have to do this just wondering if anyone has and idea of what i should do that is gonna save me the money of a diagnostic.
Old Oct 3, 2004 | 02:46 PM
HBHRacing's Avatar
Re: car starting problems
a fuel pressure test would be a logical place to start
Old Oct 12, 2004 | 05:07 PM
94m5's Avatar
Run a pressure check. Low fuel pressure will definatly cause a hard start problem. Try this as an easy way to check. Before you start the car, turn the key to the run position (Don't crank it over), and let the fuel pump prime. Right after the pump relay shuts down, crank it over. If it starts right away, your gonna be replacing the fuel pump soon.
Whats happeneing during this exersise is, The pump is increasing pressure to the injectors so they can spray the correct ammount of fuel to the cylinders. It should normally do this immediatly after turning the key over, but if it's getting weak, it takes a while to pump up. Just a little tidbit of info for ya. Mike
Old Oct 14, 2004 | 10:19 AM
drdudelove's Avatar
yea i tried priming it and it still has a hard time turning over, do the injectors need to be cleaned?
Old Oct 14, 2004 | 02:35 PM
94m5's Avatar
they could, but not likely. I'm gonna have to go with a problem with your pump. you need to get a reading with a pressure gauge.
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
