i think i screwed my engine with seafoam
Old Oct 9, 2004 | 10:55 PM
kevin 2.8's Avatar
so mixed the cleaner with 50/50 water and sprayed it into the intake
car ran fine
then put the straight cleaner into the vacume hose going to the back of the intake. the car stalls and i wait a half hour
so i come back and the car runs like hell. so i figure 1/2 the splugs are fouled. i change thme and they were all fine. car still runs like hell. it shakes its loud its smoking from the passnger side valve cover area
what the hell is wrong?
Old Oct 9, 2004 | 11:10 PM
camaros_4_lfe's Avatar
Re: i think i screwed my engine with seafoam
u did change the plugs??? or jus check them?
besides that i dunno what do you mean by running like hell?
Old Oct 10, 2004 | 12:25 AM
kevin 2.8's Avatar
its shaking real bad like a multiple plug misfire
yeah i changed the plugs
and its loud and smoking from the passenger side valve cover area too
Old Oct 10, 2004 | 01:32 AM
oil pan 4's Avatar
Did you put the break booster vacuum line back on?
I wouldn't put that stuff in my car ever, if I wanted to clean it out I would spary a can of carb/tb cleaner in there.
Old Oct 10, 2004 | 01:49 AM
kevin 2.8's Avatar
yup the line is back on
Old Oct 10, 2004 | 10:21 AM
HBHRacing's Avatar
all you can do is keep running it and see if it clears up. Sounds to me like you dumped too much and could have hydrolocked a cylender and possibly bent some pushrods/valves. it's not reall ment to be dumped in, it's ment to be atomized using a special kit that we use at shops.
Old Oct 10, 2004 | 10:33 AM
yes i was thinking that... if you dump it in u dump really slow so it atomizes with the incoming air
Old Oct 10, 2004 | 01:13 PM
kevin 2.8's Avatar
how could it screw my injectors?
i took out the 02 sensor to see if it was that, or if the cat was clogged and it ran the same.
Old Oct 10, 2004 | 01:48 PM
kevin 2.8's Avatar
so i took the new plugs out and looks like only 3 of them were firing as they were clean and wet 1,2 and 5. all the other 3 were slightly blackened.
so with the plugs and wires out of the way i turned the motor over to see if i cant dry out anything left in the cylinders. it turns over really smooth with only a whirr and a tick from the spark. im going to leave the plugs out for a fw hours.
Old Oct 10, 2004 | 03:21 PM
kevin 2.8's Avatar
put the plugs back in and still runs like hell
Old Oct 10, 2004 | 05:20 PM
kevin 2.8's Avatar
im almost convinced its hydralocked
if i take off the valve covers can i tell if the valves arent moving when i start the car?
Old Oct 10, 2004 | 06:42 PM
HBHRacing's Avatar
run a compression test and see what you have
Old Oct 10, 2004 | 08:14 PM
deadmeat2004's Avatar
are u sure u didnt crack anything when you sprayed the water in?
Old Oct 10, 2004 | 09:06 PM
kevin 2.8's Avatar
i used hot water mixed with the seafoam so i dont thnik anything cracked
ill do a compression test when the stores open again
Old Oct 10, 2004 | 10:40 PM
where are u at in ontario?
also there is still a chance u got a crack how hot was the engine?
