95 3.4 Hard Start
Old Nov 9, 2004 | 10:50 AM
Dave Holland's Avatar
95 3.4 Hard Start
Stock 95 Camaro, 135K on the clock.
Hard/rough start when outside temps are below 45deg and engine is cold. Engine will crank, fire up, then die immediately. Eventually it will start and idle normal which is still a little rough. Here is what has been done and what I have tested.
New plugs & wires. Two of the injectors were sticking open, so it now has 6 new, GM, injectors. Engine temp sensor replaced. New fuel filter.
I have tested the fuel pressure. Reads 41 with ignition turned to on, 34-36 when cranking, 44 at idle with FPR vac disconnected, 36 at idle with FPR vac connected, and 44 @ WOT. Holds pressure for hours after shut off. I don't think the fuel pump or FPR are suspect. I'm getting an intermittent SES for the EGR, no other codes.
Car has a rough idle & slight stumble when accelerating slowly. Runs like a bat out of hell at WOT. When the outside temps are warmer, it will start no problem, but still has the rough idle.
I'm leaning toward the 24x crank sensor, the ICM, or coil packs. All are original as far as I know.
Any other suggestions?
Thanks.
-Dave
armedtrigger
Feb 24, 2015 08:30 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
jayblev95
Dec 1, 2014 06:55 AM
