Bolt pattern for a V6 4l60E same as LT1 T56???
Im gonna bwe selling the A4 out out of my 94 camaro here shortly and am planning on putting it up for trade for a T56 but its gonna depend on wheter the bolt patterns are the same?
thanks,
-john
thanks,
-john
Re: Bolt pattern for a V6 4l60E same as LT1 T56???
I'm pretty sure all the bolt patterns for the different engines for fourth gens are different. And you'll have to shell out some cash, a used T56 is worth considerably more than a 4L60E. If you're dead set on it you could probably modify the bellhousing to work or have a custom one made but it would cost ya.
-john
where is the beating the dead horse emoticon, NO, no V6 trans will work on a V8 and no V8 trans will work on a V6 (unless you spend more money on it than the car is worth, but in that case i could make a turbine engine work on an F-body)
