Cooling problems.
Old Oct 4, 2004 | 01:57 PM
nothingeined's Avatar
Cooling problems.
Well I got my new water pump on and also put a new belt tensinor (sp). Filled up all the fluids and made sure they are full. Now when I drive, my car is around 195 range then jumps to 210, stays for awhile unless I give it some gas and goes to about 230-240 then drops back down to 210. If I get on the freeway and take it up to about 70-80, it cools down a bit, but then I hit stoplights and it starts doing the 210-240 range again. Did I miss something or do I have another problem?? Not enough coolant, thermostat??? Any help is appreciated. Thanks!!
Old Oct 6, 2004 | 03:55 PM
96 camaro 4 life's Avatar
Re: Cooling problems.
I did the same thing 6 mos ago, i still had the problem after changing my water pump. Figured out i had air lock. Maybe try gettin your cooling system bled.
Old Oct 7, 2004 | 12:29 AM
viper03af's Avatar
use the bleed screw buy th thermo, if not i would try a new thremo only few bucks
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 17, 2015 08:31 AM
cmsmith
Sep 14, 2015 09:09 PM
