Questions: MSD Ignition For 3800II
Old Jan 19, 2005 | 03:03 PM
NovaScotiaRS's Avatar
I have looked into MSD GM-Style 2-Tower coils and the 8.5mm wire set for my 97 V6. What I don;t understand is how MSD other products work with this engine. For example: Does a DIS-4 replace the stock ignition module? Does a DIS-4 drive the same 2-Tower coils? Does a DIS-4 interface with the stock ECM?
Regards,
Derek
Old Jan 19, 2005 | 07:31 PM
scooters97ss's Avatar
Re: Questions: MSD Ignition For 3800II
Dude; what are you doing hanging out around here?? Give me a call sometime.
Old Jan 19, 2005 | 08:10 PM
Teufel Hunden's Avatar
The Dis-4 would connect to the coils, but would not replace them. Basically though, the entire MSD line is not needed. Some of the fastest 3.8s in the country are still using the stock coils with no DIS-4.
Old Jan 20, 2005 | 12:04 PM
Tru2Chevy's Avatar
Yea, stock delco coils should last you for quite a while. My '91 Lumina uses the exact same coils (3.1L v6) and at 180k miles, I still blow the gaps on my delco plugs wide open. The last set I pulled blew from .045 to .065 over 50k miles.
- Justin
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
