Did LT1 - What to do about fuel pump?
Old Nov 17, 2004 | 11:56 AM
Faccnator's Avatar
I did the 3.4 to LT1 swap. Everything is working great. I was told that the V6 fuel pump did not have enough capacity (either in volume or pressure or something else) for the LT1. My question is can I use an inline pump, if so what should I get. I want to avoid having to drop the fuel tank and replace the stock pump.
Thanks,
Faccnator
Old Nov 17, 2004 | 12:12 PM
OutKast's Avatar
Re: Did LT1 - What to do about fuel pump?
I've got over 20k miles on my LT1 since the swap and the first 10k was running on the V6 pump only. I have heard that they are the same pump. I never had any problems. When I went to a little N20 I added an inline pump. The V6 pump is still in the tank to this day. Before the inline pump was added I was putting down 356rwhp running 12.80s. The inline was really only added for security with the N20.
Old Nov 19, 2004 | 04:13 AM
1sicv6's Avatar
you can replace it with a walbro or something similar, around 150-180 i think, my friend just did it in his lt1, and he didnt have to drop the rear end or nothing, we found a different way to do it, you cut a hole and go through the top, its about 3 hrs of work and a lot easier i can give u the link to the walkthrough if u need it
Old Nov 22, 2004 | 06:27 PM
gerard14's Avatar
that link would be awesome!!!!
Old Nov 27, 2004 | 01:47 PM
kozikot's Avatar
Can you post the link on here ????????? Thanks
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
