leaking oil pan + changing rear drum shoes....
finally replaced the the drain plug as i thought that might be the problem....but after sitting there and staring at my oil pan for 5 minutes...the leak is in the pan itself....on the bottom...and while it doesn't amount to very much at all....car is never really low....i'm just disconcerted by the fact that i have a hole in my drain pan i put some stop leak in there today....see if that does it at all....but is there something i can do to the bottom of the pan to keep it from leaking....anything i can spray it with??
secondly...
anybody ever change the shoes on rear drum brakes on a 1995 f-body and have any tips???
thanks...
secondly...
thanks...
Re: leaking oil pan + changing rear drum shoes....
i did the rear drums on my 94, all i can recommend is gettin the 2 spring tool s(they r cheap), find the hanes book big help and take a picture of each side before u start. If u r in the northwest suburbs of the chicagoland area i will be willing to help you. Also replace the springs and whatnot in the drums
