Turbo oil return lines
What are you guys doin for your oil return lines? What size are you using?
it seems like i have a 1/2 inch NPT fitting on my turbo already, but how and where are you tapping into the pan? i guess anywhere above the oil level should be fine, correct?
are you guys welding them in or is there something with an o ring that bolts through the pan?
Here too. On the drive's side.
TagZ - When you weld the fitting on, it doesnt matter where you put it as long as its high enough. If you tap the pan and thread in a fitting, then you need to worry about rotating assembly location and such
Just did mine. I put one on each side at the very front beside the first main cap. Tapped it out, used some jbish stuff, and screwed it in.
I am just using a 5/8 line. A little big I know but by turbos already had a fitting hanging off the bottom and thats the size tubing it needed.
You could cut the fittings or just not thread them all the way in. My threads were rather tights so it did not just spin in and then I had it caked in JB, Ill take a picture when I get home. I have maybe 2-3 threads sticking out inside.
