Cutting the honeycomb for an intercooler...
When you guys have cut the honeycomb 'neath the front bumper cover, what did you use to cut the stuff? A sawzall? Cutoff wheel? Hacksaw? Cutting pliers? I'm getting ready to install my OBX intercooler and I want to get the tools, etc all set up beside the front of the car to minimize running around.
Thanks!
Thanks!
Perfect! Thanks! Looks pretty straight forward. On the actual bumper cover, did you remove that black plastic inset area (where the stock front license plate box used to be) so that the incoming air could directly encounter the intercooler?
Sounds like a great idea. I like the look you already have but the one you envision sounds even better
Thanks again for the excellent pictures. Did you also use the Sawzall for this plastic as well?
Thanks again for the excellent pictures. Did you also use the Sawzall for this plastic as well?Yup... here is an old picture its now tucked up higher so I had to move the intercooler forward a little and make a new bracket for it.
I plan on cutting out the rest of the black area out and adding a black grill to the front of the car. I'm going to add the red bowtie on top of the mesh grill.
-B
-B
-B
Thanks for the kind words! I just used a utility knife with a new blade and it cut right through it like butter. I didn't want to use the cut off wheel or sawzall on the bumper since it was very ackward to try and get those tools in there. A dremel would also work wonders in there. Good luck!
-B
-B
Post some pictures of the mesh grill when you get that done. That is the exact thing I was planning on doing with the bowtie, but over a painted bar-style grill. I'd be interested to see how the mesh looks also.
-B
How about you? You should be up and running by now.
I thought I would be up and running but Im working 2 jobs now so no time to work on the car! Also the machine shop that honed my big block hub took off too much material for my crank so now its no longer a press fit but a slip fit.
I have to order a new one.... till then its holding up my entire project.
-B
I have to order a new one.... till then its holding up my entire project.-B
