Turbo cam
Old Apr 10, 2007 | 02:24 PM
detroit1994z28's Avatar
Turbo cam
Someone in my area is selling a brand new custom grind cam that was desinged for a supercharged application. I have a turbocharger. Would this cam still work good - Better then the hotcam. Also given these specs would it have a lopey idle to it??
gross lift .572in .585exh
dur @.006 tappet lift 288int 292exh
dur @ .050 236int 242 exh
lobe seperation is 114
Old Apr 10, 2007 | 10:57 PM
engineermike's Avatar
Need spec's on engine and turbo.
Old Apr 11, 2007 | 12:06 AM
Engine is basically all stock with stock aluminum heads 1:6 rockers the turbo is a sts system t-67 upgrade
Old Apr 11, 2007 | 06:12 AM
There is nothing particularly wrong with that cam for turbo use, but it's overkill on a stock engine with a little turbo. Engine and turbo will be signing off when the cam comes into power.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
