D1SC on 383LT1
Old Apr 21, 2007 | 01:14 AM
maro z28's Avatar
D1SC on 383LT1
With 415rwhp N/A on a 383 LT1(mods in sig minus stroker, 12-bolt, blower cam), how much rwhp gain will I see from 12psi from a D1SC?
A couple of threads above shows 150rwhp gain on a stock LS1 with 8psi on a P1SC! My ride is MUCH faster than a stock LS1. So, why can I or can I not see this much rwhp gain? Does it have to do with the engine's capacity for air and your ability to deliver enough fuel or something?
Old Apr 21, 2007 | 10:12 AM
LittleRedZ's Avatar
first of all you will need at least 75lbs injectors and a good fuel system something like a a1000 aeromotive pump.
At 12 psi you should see about 200rwhp gain if not more i picked up 100rwhp going from 14psi to 18psi. IF its high compression i wouldnt run any more then 12psi and probably run at least 104 octane
Old Apr 21, 2007 | 03:28 PM
maro z28's Avatar
I'm gonna get the build for lower compression, so I can run pump gas. I'll probably do meth injection, too. I was gonna stay with my Racetronix fuel system + bap for up to 10-12psi. I just want to know roughly what I could expect as far as power gains.
Old Apr 21, 2007 | 04:44 PM
LittleRedZ's Avatar
dyno it on low compression, but on 12 psi if its tuned right you should see 250rwhp gain with no issues.
Old Apr 21, 2007 | 07:12 PM
maro z28's Avatar
650rwhp would be wild...for me at least.
Old Apr 23, 2007 | 09:56 AM
LittleRedZ's Avatar
you would be close since you lowering the compression you will loose power on motor, so you wont be 400rwhp anymore. but i think it should be mid 600 numbers
Old Apr 23, 2007 | 11:19 AM
CALL911's Avatar
You are pretty much the same boat I was. N/A my 383 LT1 made 420 RWHP. I rebuilt the motor for the blower, and put a D1SC running 15#'s of boost, and I saw 590 RWHP on a Mustang dyno on a hot day. This year I am adding the methanol injection setup, and will be getting a new tune. I have been told I should see a solid 650 RWHP.
Here's a video I put together right before I yanked the motor while I was still N/A.
Click here to see Video
And here's a video of my car on the dyno after the motor was rebuilt for the boost, and my blower was installed just to give you an idea of what it is like before and after.
Old Apr 23, 2007 | 01:38 PM
T/A KID's Avatar
Call911 you did 590 on a Mustang Dyno MAN, thats like 630 alone on a Dynojet (Quit Saying 590, lol) and get rid of that crappy ATI induction and get a good induction system on that thing, lol
Old Apr 23, 2007 | 02:48 PM
CALL911's Avatar
Well, it will be re-dyno'd this year on a dynojet, with a different inlet tube, and a methanol injection setup, so it should do well, and I am hoping for around 650 at the wheels. It may do more, and that would be fine
Old Apr 23, 2007 | 05:50 PM
LittleRedZ's Avatar
was that dynoed at flowers in MD by anychance?
Old Apr 23, 2007 | 06:09 PM
CALL911's Avatar
I can't remember the exact place it was tuned. But it was in MD, and the tuner/owner of the shops name is Jeff.
Old Apr 24, 2007 | 11:02 PM
HardcoreRM125's Avatar
Call 911, what kind of fuel system are you running for that thing?
Old Apr 25, 2007 | 08:43 AM
CALL911's Avatar
I am running a dual Walbro in tank setup with a HOBBS switch that kicks in the second pump when the cars sees 4#'s of boost or more. Stock fuel lines, into 60# Mototron injectors.
Old Apr 25, 2007 | 11:22 AM
T/A KID's Avatar
Speaking of Fuel is anyone running a Boost regulated Fuel pressure regulator or the stock piece???
Old Apr 25, 2007 | 12:07 PM
ZBLKHELLRZR's Avatar
Boost regulated by Fuelab.
