air to water or methanol
Old May 15, 2007 | 03:01 PM
personoo's Avatar
I have twin 67 mm turbos on my 400 sb chevy that see some street and some track use ,and I wanted to know which would work best with my setup?
thanks for your help
Old May 25, 2007 | 02:16 PM
windsma's Avatar
everyone in the threads here says 50%water 50%meth. mix
some are saying just use regular windsheild washer fluid its premixed.
i will look at the washer fluid ingredients next time i go buy it.
Old May 27, 2007 | 12:47 PM
engineermike's Avatar
Straight Methanol works best and some are running over 40 psi boost with pump gas / 100% Meth. With water/air, you won't be able to run over 15 - 18 psi boost, but at least you don't have to fill the Methanol tank.
I have both.
Mike
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
BLOWNBIRD
May 28, 2003 01:02 AM
