ATI questions...
ATI questions...
I have said now that I finally have my car dialed in with the D1SC that I am happy with my power level and results.
However, I am curious as to what the difference would be if I changed my D1SC to an F-1A. I know the F-1A will use the same bracket as the D1SC (just need to clearance the block and the ABS a little). Does the F-1A use the same pulleys? Currently with a 7.65 crank pulley and a 3.4 blower pulley my max boost is about 14.5#'s at 6500 RPM. What would the F-1A give me with that setup?
BTW, I am running CNC by TPIS AFR 180 heads, custom EPP FMIC, and a custom camshaft 244/254 @ .050, .578/.578 lift, 114* LSA.
Boost is not addicting
I answered your questions in the other thread, Ben. Actually I think for the money you would get a pretty darned good gain out of a better set of heads. They're cheaper, and maybe you could talk Sean into lending you his F1A (when he gets it), and you can do back-to-back comparisons on your car!
I AM currently happy with my setup though, so I won't be changing it any time soon or even ever. I am just curious with changing the blower what kind of gains, or boost levels I will see.
Thanks for all the info!
After I could sell my D1SC and buy a good deal on an F1-A I think I really would be out less than upgrading my heads. But thats true that my heads and cam setup are not helping me boost wise.
SpeedJunkee
Jun 6, 2015 04:27 PM
stockssn2o
May 25, 2015 08:54 AM
Red_94Formula
Mar 7, 2015 09:21 AM
