when should you o-ring your block
Old May 6, 2007 | 12:12 AM
pete foradis's Avatar
How much boost can you run without an o-ringed block ,on an Lt1 with AFR heads, Just worried about blowing head gaskets. So when do you guys recommend doing this and what are pros and cons?
Old May 6, 2007 | 01:54 AM
FireChicken1995's Avatar
i cant answer the whole question but when i got my engine from golen it was standard for the forced induction motor to be O ringed and il go as high as 15lbs of boost. im sure that you wont have a problem blowing gaskets with a O ring block but if for some reason the O rings decide to screw up then i think you pretty much have to take the block to have new O rings installed.
Old May 6, 2007 | 02:07 AM
Blownbird355's Avatar
re
There are non 0-ringed heads holding more than 15 psi but I'm not sure when is best to go to them. Also non o-ringed blocks act as afuse sometimes preventing worse damage.
Old May 6, 2007 | 09:27 AM
Jeff 96 SS's Avatar
I wouldn't recomend it for a sreet car unless your trying to 1k+HP. I do recomend it for a race car though My copper head gaskets always seep some coolant its a pain on the street but easy to throw a little coolant in after every pass at the track.
Old May 6, 2007 | 12:37 PM
Lisa33's Avatar
Did a few 20+psi runs today widh felpro 1074 (boost gauge dont show any more than 20 )
Old May 6, 2007 | 02:52 PM
So will a lot of cylinder pressure cause head gasket to blow? or is it just form detonation?
I've got a ysi on order, and don't want to waste summer replacing head gaskets but if o-ringed blocks leak water then whats the point?
Old May 6, 2007 | 04:02 PM
Jeff 96 SS's Avatar
Originally Posted by pete foradis
So will a lot of cylinder pressure cause head gasket to blow? or is it just form detonation? Both can cause blown head gasket
You won't blow a head gasket with orings and copper but it will seep a little coolant nothing is perfect it just depends what you are looking for.
Old May 6, 2007 | 11:10 PM
sounds like im just going to stick with felpro, It's mainly for stompin on some mustang's in the street.
thanks for all the replies
Old May 7, 2007 | 07:14 AM
SMOKNZ's Avatar
Felpro 1074's and studs work great. Been up to 18 psi with that combo.
Bill
Old May 7, 2007 | 10:18 AM
Roadie's Avatar
I had the same problem with coolant and my copper gaskets... One bottle of alumaseal and it's all fixed.
(It did take a few times running it before it sealed up and stopped seeping, but it worked great).
Old May 7, 2007 | 10:46 AM
97WS6Pilot's Avatar
Bill
What he said. 15psi.
Old May 8, 2007 | 10:22 PM
Wild1's Avatar
Head Studs will help with the clamping force to seal and will be good for the street.
Old May 11, 2007 | 09:22 AM
94 NO TOP Z's Avatar
Head studs + cometic gaskets have worked for me up to 20psi.
Detonation is the key. Detonate and you will blow head gaskets, break ring lands, etc.
Old May 13, 2007 | 09:42 PM
LukeZ28's Avatar
Bill
What he said 17psi.
Old May 14, 2007 | 09:05 PM
Fastbird93's Avatar
I had my new motor O-Ringed for insurance purposes as it will be seeing 15+ PSI.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
