Ported manifold on ati p600b with 12 psi?
Old May 17, 2007 | 09:02 PM
SteveLT1's Avatar
My car is a 355 ati procharger p600b with 12 psi.
I have a 52mm throttlebody on the car and 44lb injectors which are almost maxed out.
When I decide to get new injectors, should I also consider going to a 58mm throttle body and having work done on the manifold?
Or just save the money and spend elsewhere.
Thanks.
Steve
Old May 17, 2007 | 09:24 PM
Flip94ta's Avatar
save your money and spend it elsewhere, the blower will force the air into the motor, going from a 52 to a 58 will net you next to nothing. If you were aiming for a maxed out NA build then yes. Headers, cam, bigger head unit, better heads, better intercooler etc are where its at.
Old May 17, 2007 | 09:29 PM
SteveLT1's Avatar
Yea..I'd like to get rid of the p600b. Ive had it forever but funds are short.
I think I'll look at the heads next. I have the majority of what you mentioned already upgraded.
Thanks for the input.
Steve
Old May 18, 2007 | 08:05 AM
97WS6Pilot's Avatar
Steve
I gasket matched the intake runners to the head runners for a small gain. The Holley 58mm throttle body didn't help much at all but it sure makes the underhood look alot better.
Old May 18, 2007 | 11:51 PM
engineermike's Avatar
Measure boost at the disharge of the blower, then in the intake manifold. Whatever the difference is, is what you stand to gain by upgrading the MAF and TB.
Mike
RUENUF
Mar 13, 2016 03:39 PM
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
SC97TA
Sep 15, 2002 01:10 AM
