Water/methanol users....
Old May 27, 2007 | 07:08 PM
Ponyhntr's Avatar
What is everyone using for a tank? Stock washer tank? Small fuel cell? Supplied tank that came with the kit?
I have a Snow Stage II kit, and was wanting to use the stock washer tank, but I don't know how I'm going to install the bulkhead fitting in it. You can't exactly get your hand in there to tighten it on the inside.
What has everyone else done?
Old May 27, 2007 | 09:03 PM
David94TA's Avatar
I use my windshield washer fluid tank--works for me.
Old May 27, 2007 | 09:13 PM
leadfoot94's Avatar
Windshield washer fluid tank w/ Snow Stage 2.
Used the hole that was left from removing the fluid pump for my feed.
Old May 27, 2007 | 09:57 PM
windsma's Avatar
i found a used not working in-line fuel pump used on my dads fuel inj. rv.
it is the same size as the washer pump but alot stronger. It fits perfectly, a little tight which is even better. The inlet to the pump fits just like washer pump
i have to go to advance auto and match it up when i do i will post what the part the no. is.
I thought of using a NOS TB Plate for the injection side any ideas, is a nos solenoid required or just a good idea.
Old May 27, 2007 | 10:08 PM
CALL911's Avatar
Ponyhntr, you have a PM.
Old May 31, 2007 | 02:18 PM
InsuranceGuy's Avatar
I'm using the stock supplied Snow Performance tank.
http://EDusek.photosite.com/Album7
93Z,383,Vortech,NOS,Snow-methanol
Old May 31, 2007 | 03:54 PM
CALL911's Avatar
I have both a brand new stock windshield washer tank, and a stock new Snow Performance tank I'll sell cheep to anyone who is interested.
Old Jun 5, 2007 | 09:19 PM
wicked_95z's Avatar
windshiled washer tank with an Alkycontrol Kit
Old Jun 7, 2007 | 09:37 AM
mzgp5x's Avatar
Used the Rad overflow tank. Mounted pump down lo inside Rt. front facia. B.
Old Jun 7, 2007 | 10:13 AM
92LT1RS's Avatar
what are you using for overflow now?
Old Jun 7, 2007 | 10:30 AM
mzgp5x's Avatar
Overflo to ground. I went with a Be-Cool rad unit. It was an easy convert to Meth/ H20. More capacity over the Snow tank, and sort of sleeper. I drilled a hole near the bottom tank and used seal-all glue and buna-n made gasket washers between large dia. alum washers/ 1/4 tube bulkhead fitting. It sealed good. No leaks to date. There's alot of mount options down there for pump brackets. Hope this helps. (97ss 383 - D1) B.
Old Jun 7, 2007 | 11:03 AM
92LT1RS's Avatar
sweet, sounds like a good way to do it. I'll be keeping the overflow though, may just switch to a small catch can though.
cyteone
Jul 9, 2012 10:55 AM
94sc383
Feb 10, 2009 10:29 AM
Built LT1
Oct 18, 2006 01:56 PM
twistedwedge
Jul 27, 2002 01:54 PM
