Blower or Juice (that is the question)
Old Mar 15, 2004 | 07:57 PM
94flamedta's Avatar
Check my sig and see what you think. I wasn't sure if my compression was too high for a blower. I built it with the intent of a 175 shot but the more i think about it the more i want a blower. and if i can supercharge it then what psi do you think would be safe. Kind of a rookie at this so please don't make me explode my motor.
Old Mar 15, 2004 | 08:31 PM
mongse_1's Avatar
With that cam, definitely jug it.
Old Mar 15, 2004 | 08:33 PM
12Second3rdgen's Avatar
Nitrous.
Old Mar 15, 2004 | 08:49 PM
engineermike's Avatar
Based on your mod's, it's better set up for Nitrous.
The cam is probably on the large side for a blower. The powerband would be all top-end. BTW, the CC306 is 230/244, not 240/250 like your sig. says.
Plus, the compression's a little high. You might run 6 psi, but I'd pull alot of timing out to keep it safe. If you pull timing out, then the combo isn't living up to its potential.
And the blower wouldn't give you 175 hp at 6 psi. . .
Mike
Old Mar 15, 2004 | 08:53 PM
sleeperz28's Avatar
Make it a juice motor you will be much happier
Old Mar 16, 2004 | 01:08 AM
slomarao's Avatar
there have been people with 175 shots on shot shortblocks you may want more. The nitrous will give better results because your compression will always be holding you back if you went with a blower. Look into a 2 stage kit or a progressive controller.
Old Mar 16, 2004 | 12:49 PM
94flamedta's Avatar
juice sounds good to me. And my cam is a custom grind off of a cc306 so it is 240/250 i guess i should have stated that.
Old Mar 18, 2004 | 07:28 AM
LameRandomName's Avatar
I'm sorry, I'm not up on the newest lingo. What does "Jug It" mean?
Old Mar 19, 2004 | 07:20 AM
mongse_1's Avatar
Jug it, on the gun, on crack = nitrous
Old Mar 19, 2004 | 10:15 PM
DARCOM's Avatar
i have both nos and boost & 10.5:1 compression but it took me awile to figure how to make it all work together. but i can it works great now.
you can see it at: http://darcom.org
Old Mar 20, 2004 | 08:29 AM
rskrause's Avatar
Moderator
Agree with the nitrous suggestions. Seems like a nice combo for N2O.
Rich Krause
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
alex5366
Feb 17, 2015 09:07 AM
