superchargers
Old Apr 13, 2004 | 12:58 AM
Stumpy65's Avatar
superchargers
i am loking to put a supercharger in my Z28 and i have no idea what kind i should get or how much performance they add so just fill me in with the info that would be appreciatied thanks.
Old Apr 13, 2004 | 02:12 AM
Bersaglieri's Avatar
Got to some supercharger websites and request some catalogs. ATI Procharger always struck me as a good one, also Vortech. Powerdyne also makes one.
-Dustin-
Old Apr 13, 2004 | 02:24 AM
Stumpy65's Avatar
ya ive seen those around i just want to read some review on them all to find out which are more reliable because they all do the same thing right?
Old Apr 13, 2004 | 03:44 AM
BiGGinZ's Avatar
If you post this in forced induction you will probably have better luck. Also try searching for it in forced induction. Good luck.
Old Apr 13, 2004 | 07:02 AM
IDOXLR8's Avatar
I would honestly recommend doing a search in the force induction forum. If you are not willing to do a rebuild on your short block then a blower is not for you.
Old Apr 13, 2004 | 07:43 PM
Stumpy65's Avatar
if you need more info its a 1996 Z28 and i just want to know which superchargers are nice and what i will have to do to my car if i get one
Old Apr 13, 2004 | 11:53 PM
TonyJ's Avatar
Stock bottom end, you can spend about $3500+ to make an extra 50-100 hp at the wheels (relatively safely...) That's assuming about $2500 for a s/c kit,$500 for misc stuff like plugs, plumbing, etc. and another $500 to have it professionally dyno tuned to make 4.5 to 6 lbs. of boost. That's assuming you can install the tough parts yourself and get it tweaked by the pro...
If you want to do it right, look at spending closer to $10,000+.
For that you can get the above plus a rebuilt, forged, bottom-end and can probably crank up the s/c output to almost double your horsepower. 500 rwhp is not out of the equation at that level...
Keep in mind these estimates will probably prove to be low, rather than high...
Old Apr 14, 2004 | 04:09 PM
Stumpy65's Avatar
well i dont want to spend quite that much so what else can i do besides supercharging to get some more horsepower i already have intake and exhaust so what else can i do?
Old Apr 14, 2004 | 04:14 PM
SMOKNZ's Avatar
Nitrous
Old Apr 14, 2004 | 05:11 PM
BiGGinZ's Avatar
I am assumming you have headers sense you said exhaust, but if not then get some headers. You could go with a good cam, then ported heads with good valve springs rr's, and all that good stuff that would cost near as much as a s/c.
Old Apr 14, 2004 | 05:17 PM
Stumpy65's Avatar
do u mean wouldn't cost as much as a cupercharger cuz i can get taht but then all the other crap is a lot, so if i got that how much HP would i get outa it
Old Apr 14, 2004 | 05:30 PM
BiGGinZ's Avatar
I don't know how much you would gain with heads and a cam. I imagine you could be around 335-350rwhp with p&p heads, a big cam, full exhaust and intake. I say do what I have mentioned above then run a 100-150 shot of nitrous. But to run nitrous you might need to build the motor up more to handle it. I have no exp. with nitrous.
Old Apr 14, 2004 | 07:50 PM
GS355's Avatar
Talking what to do
You could get an STS kit . hahahahaha.
GS355
Old Apr 14, 2004 | 09:12 PM
94SLUG's Avatar
Re: what to do
GS355
and still blow your motor
Old Apr 15, 2004 | 06:31 AM
IDOXLR8's Avatar
I would honestly look at getting your heads ported and going with an aftermarket cam.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
