boost gauge hookup??
Old Mar 22, 2004 | 07:22 PM
pwrtripta's Avatar
can you guys give me a few ideas, maybe with some pics as to where you spliced the vacuum line for your boost gauge. it says any line with air, could i use the one going from near the coil that has a blue spaceship type thing on it? and before or after the blue piece?? or could i use the line that goes into my AFPR?? give me some help, i know its a dumb question but my brain is burnt and i just want this done along with my countless other things goin in the car.
Old Mar 22, 2004 | 07:50 PM
Roadie's Avatar
first one, no. that blue spacer is a one way valve going to your opti. since air will only go in one direction, you will either see boost or vacuum, but not both.
the second is a yes. Any line coming out of your intake manifold without a one way check valve will work -- as long as it doesn't have a leak.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
themex2002
Sep 2, 2015 03:47 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
