Oil Out Of Dipstick ?????
Old Apr 12, 2004 | 05:57 PM
sseul8r's Avatar
i have a supercharged 6 psi vortech 99 ss with 55 k on the engine and i was revving the car with the oil dipstick kinda out and some oil shooted out of the dipstick tube is this normal or what could it be ???
Old Apr 12, 2004 | 07:07 PM
96SFLZ's Avatar
Sounds like a bad case of "blow-by."
It's a problem that shouldn't come as a surprise...when you're running FI on a stock bottom-end. You're probably going to have to put some new rings in there and you might as well beef up the bottom end while you're at it. It will hurt performance because you're losing compression...don't ask me how bad it'll hurt the longevity of the motor.
This is just my guess, someone correct me if I'm wrong.
Old Apr 12, 2004 | 10:19 PM
AL SS590 M6's Avatar
Moderator
Re: Oil Out Of Dipstick ?????
Heck an NA engine would probably do the same thing. Why do you think that they have an O-ring on the dipstick? Solution, don't run the motor with the dip stick pulled.
Now if it starts blowing the dipstick out then grab you wallet.
Old Apr 12, 2004 | 11:40 PM
Loony's Avatar
How is that blow by....I'm not seein it....I could be wrong but I don't think its supposed to shoot out, maybe you have too much pressure down der
Old Apr 13, 2004 | 12:14 AM
anasazi's Avatar
also known as blowby
Old Apr 13, 2004 | 12:25 AM
Loony's Avatar
I thought blow by was when it blew by the piston rings
Old Apr 13, 2004 | 07:32 AM
anasazi's Avatar
correct
the FI is forcing itself past the rings into the crankcase, where the dipstick is
Old Apr 13, 2004 | 07:06 PM
Gearhead6s's Avatar
welcome to my world
Old Apr 13, 2004 | 11:48 PM
SC97TA's Avatar
How long have you had the supercharger in the car?
Has the PCV system been modified to accommodate the FI.
Kris
Old Apr 14, 2004 | 04:32 PM
Gearhead6s's Avatar
in my case i am 99% sure it is blowby. i have tried every possible configuration with my PCV but i still get a ton of white smoke out the valve covers and dipstick and oil cap. i am too lazy to do a leak down test cause i don't really want to know for sure.
Old Apr 14, 2004 | 05:59 PM
Bryan 94 Z28's Avatar
I was getting a foamy buildup on the inside of my driver's side valve cover and couldn't figure it out. I rebuilt the engine and found a broken compression ring on the number 1 piston.
Guess I didn't have problems with the oil dipstick though......
dolfan324
Jul 17, 2015 10:34 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
