Cam/blower Question
Old Mar 12, 2004 | 09:33 PM
robb4964's Avatar
Cam/blower Question
Duration @ 0.050" (I/E): 226/236
Lift (I/E): 0.525"/0.525"
Lobe Separation: 110
RPM Range: 2500 - 6500
Here are the specs for my cam , I fear that the lob seperation is not compatable w/my blower setup . The cams lobe speration is 110 .
Do you think i should go ahead and use this cam w/my procharger ? Will it still make pretty good gains ?
Old Mar 12, 2004 | 10:25 PM
rskrause's Avatar
Moderator
That cam has more overlap than is optimal for a blower cam. But you will still gain a lot of hp. Why not try it and if you aren't satisfied (or when you get the urge) swap out the cam? You could always wait for when the motor is out anyway (after it blows up)
Rich Krause
Old Mar 12, 2004 | 10:34 PM
robb4964's Avatar
Rich Krause
LO)L...lets hope it dont blow up . I guess I could try it .
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
