Question about P600b install!
Old Mar 2, 2004 | 11:29 AM
slimdawson's Avatar
When you guys had to rotate the small coolant tube on the driver's side of the water pump, did you have any issues with water leaking?
I haven't gotten to that part yet but it has been on my mind.
Thanks,
Old Mar 2, 2004 | 11:38 AM
IDOXLR8's Avatar
Never had an issue with a coolant leak. What I did was use a long extension and put it into the waterpump fitting and rotated it. You will notice it will take some elbow grease to get the fitting to rotate.
Old Mar 2, 2004 | 10:43 PM
TimbrSS's Avatar
that was my experience too... be carefull when you run your new extended coolant line to this fitting, if you run it up the pass side of the radiator and over to the fitting, make sure it doesn't kink where it turns to go up. It's kind of a tight spot, so you woulnd really notice the line was kinked if you weren't looking for it.
Old Mar 3, 2004 | 12:18 PM
slimdawson's Avatar
Unfortunately, the guy who sold the kit to me did not include that piece of hose so I have to find another. That were a lot of little pieces that didn't make it into my used kit
Old Mar 3, 2004 | 11:00 PM
Metlegleo's Avatar
Instead of cuting the hard line and using a compression fitting on the lower hose I just straightened the hard line towards the front of the car and used about a 3 foot section of heater hose and a small piece of hard line to connect the two soft sections to return to the water pump. No clearance issues and not problems.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
