FDelphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence?
Old Mar 23, 2004 | 06:24 PM
Formula Fbody's Avatar
Has anyone tried the Delphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence. How do these injectors work at idle? I see that you can use these with the stock computer. If you have used them please let me know what you think of them?
Thanks,
KEN
Old Mar 23, 2004 | 07:12 PM
rskrause's Avatar
Moderator
Re: FDelphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence?
Thanks,
KEN
You can't use low impedance injectors with the stock computer, unless you buy LJ's low impedance converter box.
Rich Krause
Old Mar 25, 2004 | 10:02 AM
Pro Stock John's Avatar
There is a GP on Mototron 60 lb injectors on www.ls1tech.com in the FI section by Nasty Performance.
Old Mar 25, 2004 | 11:37 AM
Birdie2000's Avatar
Got my Mototron 60#ers from http://www.fullthrottlespeed.com
$55 each.
Old Mar 25, 2004 | 06:42 PM
Jesse_Boyer's Avatar
I've got a set of 55's just laying around if youre interested. I'd let them to pretty cheap.
Old Mar 28, 2004 | 10:59 AM
10secz's Avatar
$55 each.
I'd like to hear how they work out for you. My experience with big high impendance injectors was lousy. I had to set the offset up to ~1.0 ms, and the throttle response was never smooth.
I'm running Delphi 95's on the street now, the idle and throttle response are perfect. And I'm using the *stock* offset table.
Old Mar 28, 2004 | 11:40 PM
Birdie2000's Avatar
Kurt Urban of Wheel to Wheel (shop that built Ronnie Duke's car) recently made a few comments about them over on LS1tech.com. He seemed to really like them, seemed very impressed. He goes by "427" over there if you care to look them up. I sure hope they work well though, sure are a lot cheaper than a FAST setup.
Old Mar 29, 2004 | 08:15 PM
10secz's Avatar
So is the Acceleronics box! That box and a set of low impedance 75s, 85s, or 95s and you're set to cruise the street and run 145 at the strip.
Old Mar 30, 2004 | 09:04 PM
MIGHTYMOUSE's Avatar
i used the stock injector offset on my mototrsons with no idle problems at all.
AdsoYo
May 2, 2018 03:21 AM
RUENUF
Mar 13, 2016 03:39 PM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
