Timing Question on Vortech Setup.
Old Mar 26, 2004 | 07:24 AM
RealQuick's Avatar
On a vortech S trim with the 6psi pulley, what is the max timing I should run without an intercooler. Forget about the retard, what should the computer see (33, 34, 35 degrees etc.)?
Old Mar 26, 2004 | 01:12 PM
rskrause's Avatar
Moderator
Re: Timing Question on Vortech Setup.
Otherwise stock shortblock? In that case, I'd say 26-28 degrees max advance.
Rich Krause
Old Mar 26, 2004 | 07:55 PM
RealQuick's Avatar
Re: Re: Timing Question on Vortech Setup.
Rich Krause
Yes, on stock shortblock. So the 26-28 is before the 1 degree retard per psi of boost? Example: If i run 26 degrees advance, and run 6psi, my timing at 6 psi will be 20 degrees advance right? Just making sure.
Old Mar 26, 2004 | 09:31 PM
rskrause's Avatar
Moderator
Re: Re: Re: Timing Question on Vortech Setup.
I'm sorry. I meant to imply that your total timing would be good in the 26 degree range.
Rich
Old Mar 28, 2004 | 12:21 PM
RealQuick's Avatar
Re: Re: Re: Re: Timing Question on Vortech Setup.
Rich
OK. No problem. So 26-28 degrees after the timing retard. Thanks again.
HectorM52
Jun 23, 2016 08:42 PM
onefastgta
Mar 19, 2015 10:10 AM
Brent94Z
Mar 21, 2002 04:44 PM
