BAP vs Twin in tank.
Old Mar 2, 2004 | 12:04 AM
Highlander's Avatar
Which way should I go to say max 700rwhp not a hp more?
I know Richard Kraus did 733 with a BAP and a 340M which is what I have.
BAP quoted from kennedydynotunning is around 260... Twin in tank will be more or less that + installation, which I prefer not to go through again
Old Mar 2, 2004 | 06:17 AM
IDOXLR8's Avatar
I made 705 rwhp hp with a twin intank setup. IMO the thing works like a charm. Also I am still running stock fuel lines.
Old Mar 2, 2004 | 10:28 AM
Roadie's Avatar
I don't care too much for the way a boost-a-pump works. The pump was meant to run at 12 volts -- i don't like the idea of zapping it with a binch of extra juice to make it pump more.
With that said, it has been proven to handle the power... How long have setups like this lasted?
My vote goes for the twin in-tank, but I'd rather do the extra work once to avoid spending more and doing it a second time (learned things like this the hard way in the past).
Old Mar 2, 2004 | 10:30 AM
Highlander's Avatar
I figured this pump with the racetronix harness was going to widstand 600rwhp which was my final goal.. well.. it did... and at 55psi I might add. Now I want a bit more power...
Sometimes is not enough...
Old Mar 3, 2004 | 04:52 PM
Racetronix's Avatar
Contact Thunder Racing as they sell the MSD BAP for $229.99.
P/N 17-2350
Old Mar 3, 2004 | 06:29 PM
boosted-lt1's Avatar
IDOXLR8 -
Would you say you still had some more room to move up in HP with that pump?
Old Mar 3, 2004 | 06:46 PM
IDOXLR8's Avatar
Originally posted by boosted-lt1
IDOXLR8 -
I think I can hopefully push another 100 rwhp out of the setup.
Old Mar 3, 2004 | 07:40 PM
Racetronix's Avatar
Set the BAP between 16-16.5V. Any higher and the pump will start to cavitate.
Old Mar 3, 2004 | 07:45 PM
Highlander's Avatar
That will support how much more flow of fuel? power?
Old Mar 3, 2004 | 07:48 PM
Racetronix's Avatar
50-100RWHP depending on the FP and motor's BSFC.
Old Mar 3, 2004 | 08:01 PM
Highlander's Avatar
I do not think more than .60
actually that pump and your harness gave me good till 607 and no drop in fp.
Old Mar 3, 2004 | 08:06 PM
Racetronix's Avatar
Are you running stock lines?
Old Mar 3, 2004 | 08:07 PM
Highlander's Avatar
Yes sir.. RSkrause did so too and he had 733rwhp with a BAP and a bosch 255lph..
ACtually.. Thanks.. I've been very happy with the setup... very happy
Old Mar 3, 2004 | 08:16 PM
Racetronix's Avatar
For the bucks you can't beat it...
When you get the MSD BAP set the max voltage to the thick red wire going into the module to 17V. This will put you at about 16.5V in the tank as the small length of factory wire and connector lose apx. 0.5V.
Old Mar 3, 2004 | 08:18 PM
Highlander's Avatar
Perfect.. thanks.. I will do!!!!!! THANKS!!!!
Got any specials on 75# inj?
