Alcohol Injection Results
Old Mar 9, 2004 | 10:54 PM
Alvin@pcmforless.com's Avatar
Hey guys,
I managed to mount a remote temperature probe to measure airtemp from the blower.
Because this is a roots setup, i don't have much room for drilling and tapping for a sensor. SO.. I took a spare 3/8's nipple I had under the blower sent it to a PCV elbow with a sensor with the other outlet going to the inlet of the blower with a vaccum restrictor.
So, pressure enters the elbow goes around the sensor and is then sucked back into the blower inlet.. The big idea is a airflowover the sensor. I think this should be good... What do you guys think?
Anyways I took it out and it seems like under 3-4 second burst in 2nd gear at 9psi only manages to pull up the temperature by about 2-3 degrees. (around 100 F) Am I dreaming? thats extremely cool for a blower and realy good for a roots blower car
Old May 10, 2004 | 01:29 AM
Highlander's Avatar
I think that that flowover you are doing is not "compressing" the air because its acting like a bypass valve... so the air cools down again when it expands on its way through the sensor...
drt
Sep 27, 2015 04:39 PM
HAWG
Sep 25, 2015 11:41 AM
Henson071
Aug 4, 2015 09:32 AM
