Post your boost and kind of fuel
Old Mar 31, 2004 | 10:16 AM
sleeperz28's Avatar
From what I have gathered their is no formula for the amount of boost you can run based on octane level. Timing will play a part in this I know. Assume max power in these conditions. The best opinon I could get is 2psi per 3 octane points. So if I can run 12psi safe on pump gas then I can run 22psi on 110, based on this theroy.
C-16 is getting very expensive around here. Im not sure at what point I should run it. I was thinking anything more then 22psi, but I dont know.
Post your boost/timing and amount of octane you run. Ill start:
20psi, 109 motor octane, 27*
Old Mar 31, 2004 | 11:48 AM
IDOXLR8's Avatar
I run 14 lbs at 26* (C16 gas). I run C-16 gas more for safety purposes than anything else. I am looking to step up the boost to 18lbs and probably bump the timing up 2 degrees. BTW my compression is 9.5:1
Old Mar 31, 2004 | 12:09 PM
97ChameleonTA's Avatar
Moderator
Wouldn't you think the static compression ratio would factor in as well?
Marty
Old Mar 31, 2004 | 12:24 PM
sleeperz28's Avatar
Marty
Yes. From my example 12psi is safe for me, but i could probably go to 15psi with my 8.5:1...
Keep em' coming
Old Mar 31, 2004 | 01:33 PM
CJ's Avatar
CJ
15#s, pump gas, 23* timing, 8.9:1 compression
next setup im shooting for 18+#s on pump gas.....we'll see.
Old Mar 31, 2004 | 02:14 PM
Sneakin Deacon's Avatar
7psi S-Trim, 24*, 93 octane. 10.4:1 CR
might wanna look into alky injection. friend of mine julio makes them in progressive kits and in regular WOT or psi based kits.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Aug 17, 2002 02:20 PM
